8 November 2025 at 1:53 am
#501177
Since I need to change the sample rate in FIR Designer to 96 kHz to match the miniDSP Flex sample rate, could you please tell me where exactly the sample rate should be set in FIR Designer? I see that sample rate can be changed in the main Setup tab and also in Channels/Export/FIR setup (FIR output sample rate). Where should I change the sample rate to 96 kHz in FIR Designer to ensure it matches the miniDSP sample rate 96kHz?
Also I’m sending you the FDS file by email so you can see how I’ve set up all the changes we’ve discussed so far. Could you please check whether I’ve configured everything correctly?
Thank you!
