Support Forums › Forums › FIR Designer M Support › Q is not importing into Powersoft ArmoniaPluse correctly › Reply To: Q is not importing into Powersoft ArmoniaPluse correctly
3 September 2026 at 9:20 am
#501364
Can you open the XML file in a text editor? Are Q’s for the High Pass VarQ and Low Pass VarQ filters 0.7 in the file? If so, the problem is in FIR Designer. If not, then the problem is in Armonia’s loading of the XML.
This reply was modified 1 month, 2 weeks ago by
EA Support.
