Support Forums › Forums › FIR Designer M Support › Q is not importing into Powersoft ArmoniaPluse correctly
    • 3 September 2026 at 9:12 am #501363
      When I export an XML file from Fir designer for Powersoft and then import it in to Armonia, the Q for High Pass and Low Pass filters come in as 0.7 regardless of what is set in the VarQ filter in Fir Designer. I have to correct the Q after importing.
