Support Forums Forums FIR Designer Support Audio Weaver? Reply To: Audio Weaver?
    19 July 2024 at 5:50 am #864
    Hi, sounds great. Can you send me example files for IIR and FIR exports and I can check the compatibility with audioweaver. exports can for instance be a very simple notch filter with high q at eg 1kHz at 192kHz. or something that is esy to check the response with.
    IIR filter coefficients. (1 kHz parametric) As I mentioned, you will have to reformat this into the Audio Weaver IIR format.
    IIR Mode: Generic
    Sample Rate: 192000 Hz
    BAND_PASS, 1000.000 Hz, BW 0.100 (Q 14.424), -18.000 dB
    b0:0.9972142660601733 b1:-1.9925586940177016 b2:0.9964118404059917
    a0:1.0000000000000000 a1:-1.9925586940177016 a2:0.9936261064661650
    FIR filter coefficients. (8 kHz parametric @ 192 kHz)
    -0.0000019375039788
    -0.0000232909935586
    -0.0000758247118155
    -0.0001577684225758
    -0.0002536402517382
    -0.0003375785563122
    -0.0003806458777341
    -0.0003600218851906
    -0.0002672051471814
    -0.0001124412132315
    0.0000768528236013
    0.0002754406778163
    0.0004692162199241
    0.0006441166692910
    0.0007863651989000
    0.0008834594664572
    0.0009251443805420
    0.0009043001381536
    0.0008176773358068
    0.0006664164956752
    0.0004562996333595
    0.0001976961691552
    -0.0000948161329911
    -0.0004031534138473
    -0.0007067267993813
    -0.0009836953623115
    -0.0012124029466288
    -0.0013729128660081
    -0.0014485410860388
    -0.0014272809420494
    -0.0013030116984123
    -0.0010763898981854
    -0.0007553365979180
    -0.0003550548397282
    0.0001024608286572
    0.0005894287216107
    0.0010737690034379
    0.0015210120681159
    0.0018965267820085
    0.0021679389141650
    0.0023075864938583
    0.0022948439602578
    0.0021181425273087
    0.0017765213229326
    0.0012805630181050
    0.0006525984915125
    -0.0000738935966857
    -0.0008557166151836
    -0.0016421838490426
    -0.0023780551493860
    -0.0030070364142187
    -0.0034756447631067
    -0.0037372004506754
    -0.0037556777985834
    -0.0035091347853864
    -0.0029924466401208
    -0.0022190939858139
    -0.0012218006777558
    -0.0000518790412984
    0.0012227820579555
    0.0025210620555950
    0.0037531674504143
    0.0048261908815694
    0.0056503689635330
    0.0061456626782458
    0.0062482290933773
    0.0059163232581452
    0.0051351685731231
    0.0039203653361848
    0.0023194711579421
    0.0004114819522030
    -0.0016959355985924
    -0.0038714658761087
    -0.0059672698116513
    -0.0078279035251081
    -0.0093005670800435
    -0.0102460863020317
    -0.0105499260446842
    -0.0101324680576485
    -0.0089577687671553
    -0.0070400473325015
    -0.0044472446479231
    -0.0013011382739891
    0.0022263084819802
    0.0059204518921650
    0.0095351553934262
    0.0128072146580754
    0.0154733086390786
    0.0172885232716711
    0.0180452967146366
    0.0175914990222077
    0.0158463001243065
    0.0128125092138900
    0.0085841922907435
    0.0033485929252738
    -0.0026183120184846
    -0.0089629079415230
    -0.0152715376918720
    -0.0210939761088650
    -0.0259716940474163
    0.9713310282009791
    -0.0259716940474163
    -0.0210939761088650
    -0.0152715376918720
    -0.0089629079415230
    -0.0026183120184846
    0.0033485929252738
    0.0085841922907435
    0.0128125092138900
    0.0158463001243065
    0.0175914990222077
    0.0180452967146367
    0.0172885232716711
    0.0154733086390786
    0.0128072146580754
    0.0095351553934262
    0.0059204518921650
    0.0022263084819802
    -0.0013011382739891
    -0.0044472446479231
    -0.0070400473325015
    -0.0089577687671553
    -0.0101324680576485
    -0.0105499260446842
    -0.0102460863020317
    -0.0093005670800435
    -0.0078279035251081
    -0.0059672698116513
    -0.0038714658761087
    -0.0016959355985924
    0.0004114819522030
    0.0023194711579421
    0.0039203653361848
    0.0051351685731231
    0.0059163232581452
    0.0062482290933773
    0.0061456626782458
    0.0056503689635330
    0.0048261908815694
    0.0037531674504143
    0.0025210620555950
    0.0012227820579555
    -0.0000518790412984
    -0.0012218006777558
    -0.0022190939858139
    -0.0029924466401208
    -0.0035091347853864
    -0.0037556777985834
    -0.0037372004506754
    -0.0034756447631067
    -0.0030070364142187
    -0.0023780551493860
    -0.0016421838490426
    -0.0008557166151836
    -0.0000738935966857
    0.0006525984915125
    0.0012805630181050
    0.0017765213229326
    0.0021181425273087
    0.0022948439602578
    0.0023075864938583
    0.0021679389141650
    0.0018965267820085
    0.0015210120681159
    0.0010737690034379
    0.0005894287216107
    0.0001024608286572
    -0.0003550548397282
    -0.0007553365979180
    -0.0010763898981854
    -0.0013030116984123
    -0.0014272809420494
    -0.0014485410860388
    -0.0013729128660081
    -0.0012124029466288
    -0.0009836953623115
    -0.0007067267993813
    -0.0004031534138473
    -0.0000948161329911
    0.0001976961691552
    0.0004562996333595
    0.0006664164956752
    0.0008176773358068
    0.0009043001381536
    0.0009251443805420
    0.0008834594664572
    0.0007863651989000
    0.0006441166692910
    0.0004692162199241
    0.0002754406778163
    0.0000763797307071
    -0.0001069720355379
    -0.0002412195372606
    -0.0003066406896947
    -0.0003027475159336
    -0.0002462479665344
    -0.0001641721731841
    -0.0000846309470683
    -0.0000282164227860
    -0.0000026308985722
