Support Forums Forums FIR Designer Support FIR Designer question Reply To: FIR Designer question
    2 February 2025 at 10:48 am #989
    Hello,
    This is my first time using FIR Designer and I’m just practicing a bit. I previously created everything through RePhase.
    what catches my eye, in the export window, (filter delay examples) (filter length examples). Do I understand correctly that the filter length is samples = taps. and I can move the IR peak within my taps? In RePhase I just registered the maximum tap count of my FiR blocks in Sigmastudio and that’s it. It would be nice if you could help me as quickly as possible with simple means. Thank you very much EDDI
    i can use 9500TAPS for one
