Support Forums › Forums › FIR Designer Support › Creating the same filter at a different sample rate..
    • 22 August 2023 at 5:23 pm #686
      >> We have been using FIR Designer for many years now. We have created FIR
      >> using the same, but the filter created was at a 48Khz sampling rate. Now
      >> we want the same filter to be converted to a 96 kHz sampling rate. Can you
      >> guide us on the same?
      If you have the FIR Designer project file,
      – load the project,
      – change the ‘Design sample rate’ to 96 kHz,
      – on the “Export” tab, double the delay and length settings (in samples), and
      – export the filter. All done!
      If you don’t have the project file,
      – in FIR Designer start an empty project
      – load your 48 kHz filter on the Target tab
      – use the FIR tabs in the workflow to change the Import (which is just an impulse) to match the Target (the old filter)
      – the adjust delay and length settings on the “Export” tab and export the filter.
