Support Forums › Forums › FIR Designer M Support › FIR Latency Question
    • 14 July 2022 at 4:45 pm #515
      BACKGROUND
      From Symetrix support
      Thanks for reaching out. While I’m not entirely sure why there is a discrepancy between the expected 8.3ms and the measured 1.56ms, I would maybe think that the 8.3ms is a max length? As in, your FIR designer at 512 taps expects to see up to 8.3ms of latency.
      Is this causing an issue with your Jupiter software or were you just curious as to why you’re getting lower latency than expected?
      Thank you!
      Technical Support Engineer
      support@symetrix.co
      Dear Support team
      Please load attached FIR (csv) file for Jupiter8. (Smaart measurment files also included)
      JUPITER-8 > Sound Reinforcement #9 > Import FIR file for Speaker voicing.
      I measured latency time from input to output for Jupiter8.
      Results are below.
      FIR ON latecy time 1.56ms from device Input to Output.
      FIR OFF Latency time 1.56ms
      According to FIR designer 512tab FIR filters latency is 8.3ms.
      Why Latency times are so short with Jupiter FIR processing?
