Support Forums Forums FIR Designer Support How can I use LM44 with FIR Designer?
  • 1 February 2023 at 6:25 pm #617
    FIR Designer can push settings to the Lake FIR 3-way module.
    FIR Designer M can push settings to the Lake FIR 3-way module and the newer Lake XP (1,2,3 & 4 way) modules.
    The last we checked, the LM series processors couldn’t load any of these modules, however this may have changed with version 7 of the Lake Controller. I’d suggest running the Lake Controller, loading a virtual LM44 and see what FIR modules you can load to this virtual frame.
    Then if you’re a licensee of ours, you can install our Lake Controller plugin which interfaces with FIR Designer and FIR Designer M.
