Support Forums › Forums › FIR Creator Support › How to load a FIR filter and show it applied to a loudspeaker measurement?
    • 5 February 2022 at 6:17 am #404
      From N
      >> Is there some way to open an FIR filter (not FIR Creator project) in FIR
      >> Creator and observe its response on a loudspeaker measurement?
      Good question. Currently no, but it’s a great idea and something we should add to all our products.
      The only way I can think to maybe approximate this (if the FIR filter is not too detailed) is
      – open FIR Creator
      – on the Target tab, select “File” and load the FIR filter
      – uncheck “Mag only”
      – use the “Mag Adjust” and “Phase Adjust” to match the “Target.” (Don’t use Auto Mag and Auto Phase.)
      – load the loudspeaker measurement on the “Import” tab.
      – on the “Export” tab, check “Show FIR filtered loudspeaker”
