Support Forums › Forums › FIR Designer M Support › Importing FIR filters into miniDSP?
    • 16 January 2025 at 6:37 am #981
      Hello, I tried to import FIR file from Eclipse to miniDSP, but it is not possible. I export from Eclipse Binary file (32 bit, float), bin format, but it is not possible to import in miniDSP. MiniDSP doesn’t recognize it. According to miniDSP they support .txt and .csv formats. I tried with your .txt and csv but no success. MiniDSP doesn’t recognize it. Usually I use file like attached which is easy to import in miniDSP. Can you check how to import your FIR files in miniDSP? Best Regards! Tihomir
      This link that I previously provided to you clearly explains the process using .bin files.
      https://docs.minidsp.com/product-manuals/flex/dsp-reference/fir-filtering.html
      and we verified it again a few days ago on a miniDSP Flex that we have here.
