Support Forums › Forums › FIR Designer M Support › include “.” in file names
    • 13 September 2022 at 6:06 pm #564
      Hello,
      when I update my filters I usually create another version of the filter, naming it “V0.1,…,V1.x”, you get the idea. But when I try to save the channel or the system name with included dot for version numbers, the file name gets cut right where the dot is, leaving me with files like “filter_xyz_V0”.
      I then have to edit the file name by hand. File names with included dots are loaded without any problems, so maybe you could edit the saving behaviour?
      Thanks,
      Lukas
