Support Forums Forums FIR Designer M Support Input sample-rate change problem in 1 ch output setup mode
    • 19 August 2024 at 8:49 pm #888
      To use Lab Gruppen DTP mode, you need to change the input sample rate to 96kHz in the settings of FIR Designer, but the default setting of FIR Designer is set to 48kHz.
      In FIR Designer settings (number of output channels) 2 channel(or more) mode, you can change the input sample rate.
      However, in 1 channel mode, the input sample rate is fixed at 48 and cannot be changed. This causes a lot of confusion and difficulty for many users who are trying to use DTP for the first time. I personally use XP1way (1 channel) module every day for system tuning.
