Support Forums › Forums › FIR Creator EX Support › Lake FIR Module
    • 14 September 2024 at 7:38 am #908
      Hello, I have always used the FIR creator EX to create filters for my EV processors, now I have bought a Lake LMX48 and I am doing tests with it, with the plugin and the module I can make a maximum of 2in-6out,
      Due to the capacity of this processor, it would be possible to make a module with 1in-3out FIR and add an aux/out input without fir. Thus it would occupy 2 modules.
      or see if the processor is capable of doing 1in/3out with fir in just one module.
      If you need me to do tests with my processor, I will be very happy to do them.
      thank you so much
      The module capacity of the Lake processors is really a question for Lab Gruppen. On older processors, one “FIR 3-way” module took the space of two “Classic” modules, but I don’t know about the LMX48. If you are able to load two “FIR 3-way” modules in the LMX48, then both will appear in the “FIR Creator EX”.
      Regard adding an AUX output, AUX outputs are inherent in the module design. If a module, like the “FIR 3-way”, doesn’t have an AUX then it is not possible to “add” an AUX. If you look at all the modules available in the Lake Controller, you will see some have AUX outputs and some don’t.
