Support Forums › Forums › FIR Designer M Support › Lake XP module Multiband Limiter Tool possibly broken
    • 25 February 2025 at 7:02 pm #998
      i have problems with setting up the multiband limiter on Lake XP modules with the Lake DTP function (FIR Designer M 4.3.15). Whenever I activate the MBL (empty 1-ch project, no filters/settings used) and push the settings it adds about 9dB to my Lake module output. This can only be seen (or heard!) by measuring the module output, there is no gain setting inside Lake Controller that gets changed. Further, whatever I try to set up, i cannot figure out how to limit a single band (which should be the standard behaviour). Whenever a single band is reaching the limit, all bands get limited.
      I think that maybe the Limiter tool inside the DTP-function is broken?
      Best Regards,
      LB
