Support Forums › Forums › FIR Creator EX Support › Limiter information?
    • 16 April 2024 at 7:19 am #810
      is it possible to set a limiter information in preset to defined value of dBu or something else? If it isn\’t possible at this moment, would You be able to add it in next update (also for creator ex)?
      Our products don’t handle limiter settings. Our products are only used for the filtering aspects of processing and presets.
      (In the Lake DTP function, the core API to the Lake Controller may include limiter parameters, but limiter settings – for a specific loudspeaker – can vary, depending on the amplifier being used. So, we leave this for the user to set using the Lake Controller directly.)
