Support Forums Forums FIR Designer M Support Re: Licenses for FIR Designer M
    • 24 May 2025 at 8:55 am #1047
      I’m writing to you because I would like to buy and use on my 3 different PCs FIR Designer M.
      Is it possible to split the license in that way so I can use it on those PCs?
      Take a look at the FAQ on https://eclipseaudio.com/contact/
      Each license can only be used on one computer.
      Which measurement software is best for importing system measurements?
      We don’t recommend any one measurement software program. There are many to choose from, and your choice depends on your application. For example whether you are designing loudspeakers and measuring in anechoic or quasi-anechoic environments, or tuning installed PA systems.
      Information on the measurement formats that our software can load can be found at
      Loudspeaker Measurement Import File Formats
