Support Forums › Forums › FIR Designer M Support › Y-Axis Scale difference
    • 17 June 2026 at 10:40 pm #501315
      The vertical axis scale of the FIRDesigner import window is +10 to -30dB. However, Smaart’s is +18 to -18. Due to this difference, when I import a graph, part of the line is obscured at the top of the window. Therefore, I have to adjust it to +20 to -20 every time I start working, which is a cumbersome process every time. It would be great if you could make the FIRDesigner window scale the same as Smaart’s, or if users could fix it via a custom setting.
      • This topic was modified 5 months, 1 week ago by eddie kim.
