Support Forums › Forums › FIR Designer Support › Unable to push FIR filters to 1-Way module via DTP in Lake Controller
    • 4 February 2026 at 7:19 pm #501208
      Hi Team,
      I’m using FIR Designer with a Lab Gruppen PLM+ 12K44 amplifier and trying to push FIR filters to Lake Controller using the DTP (Direct-to-Processor) option.
      I have created FIR filters for a 1-way configuration in FIR Designer. While purchasing FIR Designer, I received the Lake Controller plugin, but it only provides access to the FIR 3-way module. Because of this, I’m unable to load or push FIR filters to a 1-way module in Lake Controller via DTP.
      I’d like clarification on the following
      1)Do I need FIR Designer M to push FIR filters to a 1-way module? If so, does FIR Designer M include a 1-way FIR module file in the same way the FIR 3-way module file is provided with FIR Designer while purchasing it?
      2)Is there any alternative workflow in FIR Designer to load FIR filters onto a 1-way module in Lake Controller? Or is FIR processing via DTP limited to the FIR 3-way module with the standard FIR Designer license?
      Any guidance on licensing or supported methods for deploying FIR filters to a 1-way module would be appreciated.
      Thank you for your support.
